No start after Pac Brake install/Now VP electrical issue
- Replies 17
- Views 3.1k
IBMobile 7 posts
5akman 7 posts
Tractorman 2 posts
Mopar1973Man 1 post
Popular Days
Yep, I just need to now figure out what get triggered when so I can determine what is NOT happening to let it start. I'm going to call Blue Chip in the morning and see what they have to say after doin
So, I called Doug at Blue Chip Diesel first thing this morning and left a message. He promptly called me back with a couple simple things to try. After getting home from work, I pulled the center plug
I've spent the last two days working on the install of a new hx 35/40 turbo and pac brake unit. Today I finished up and went to start it with no luck. It initially ran a couple of seconds on numerous attempts to start it and then just completely quit trying to fire.
Details:
A few weeks ago I installed a kill switch in the grounding wire of the fuel pump relay. If I forget to switch the hidden switch to "on" it spins over but won't start and throws code 1689. Today, the spinning but no starting reminded me of the result of the kill switch being in the off position so I wired the relay back to stock configuration to rule out an issue with the switch with no luck. I also swapped relays in the PDC but the problem remained the same.
I get 20psi out of my lift pump but no fuel out of the #1 injector line when I spin it over with that inj line cracked open. I can hear and feel the frame mount FASS DRP run during the "free 25 second" pump test.
I started the Blue Chip Diesel diagnostics but only got as far as confirming power on pin #7 in start/run and I did an ohm check on pin #6 and it appears to be grounding correctly. It got dark so I'll pursue the rest of the Blue Chip diagnostics tomorrow. I also checked fuse #9 in the interior fuse panel per Blue Chip.
I have gone over all the Pac Brake connections and everything is done as detailed in their directions. I do get a 0753 error code however which has to do with a shifting into overdrive issues.
I removed the hot leads from the grid heater and gave a short wift of starting fluid across the intake horn and the truck fired for a moment.
I will also remove the 3 prong data connector that has the pig tail with the Edge EZ plug at the end. Maybe by removing the Pac Brake plug and going back to the previous connection of just the Edge plug into the data link connector will remove one variable.......
All the normal lights come on including the wait to start light at the turn of the key.
If anyone has any ideas, I'm all ears! I have to have this truck running for getting to work Tuesday morning so I have tomorrow to figure this out!
Edited by 5akman
additional info added
