A/C getting warm after two recharges
- Replies 10
- Views 2.9k
jaredwins 4 posts
IBMobile 3 posts
01_Cummins_4x4 1 post
Tractorman 1 post
That shows that the static high and low sides pressures have equalized and there is enough pressure to close the low-pressure switch and energize the clutch coil. I check temperature outpu
The leak detector dye should still remain in the system, and is probably the easiest way to locate a leak vs using soap and water. Yes, the water drain is located on the passenger side fir
The dye mixes with the PAG refrigerant oil and lasts forever. At the point there is a leak there will be fluorescent staining from the dye. Glasses with UV light or sniffer are best. S
First off, thanks to Moparman and IBMobile's A/C troubleshooting tips. I'm not mechanically inclined, and A/C is a mystery to me, but after spending a good portion of the day reading, and watching videos I'm starting to understand.
Some background - took to the shop, mechanic recharged and put dye in, A/C was good for ~1 month then started blowing warm. Took back, he couldnt find the leak, recharged with dye and kept it for a week, blowed for ~1 month, now it's warm again. I believe he used a Freon with leak patch.
Since it's a time and money commitment to get it to him, I got a loaner Manifold gauge and Vacuum pump and set it up tonight.
With the truck off, not warmed up:
LOW side = ~82
HIGH side = ~80
Should I have started the truck up and measured like that? "Dodge along with other manufactures suggest to do it with: the engine at full operating temperature, the engine rpms at 1000 (others say up to 1500rpm), A/C control set to A/C-Max, temperature control to cold, fan speed at max (others recommend a medium fan speed), doors and windows closed with thermometer in the center vent. "
It's ~85 degrees here, so per IBMobile's guide, my High side should be 190+ so that means my problem is:
Refrigerant is low or restriction in accumulator or evaporator.
High Side: Low
Low Side: Normal
Am I on the right track?
When truck is warmed up, the Compressor/Clutch kick on and off multiple times a minute making me think the refrigerant is low...but it's weird cause the mechanic recharges, it blows cold for a month, then blows warm even with a decent Low number...
I've seen two guys on Youtube reporting that they replaced their A/C Orifice Tube line and Accumulator/Receiver/Drier to fix it. Should I just do that? Or are there some more steps I should take?
To pull those two units, do I need to evacuate the entire A/C system?
The Evaporator is near the heater core, which basically requires a dash pullin, right?
Any simple way to dye test, or sniffer test this?
_______________________________________________
tl;dr AC blows warm. Took to mechanic twice, he couldnt find leak. He recharged and used a leak patch with dye. Measured with A/C Manifold tool and LOW=82 and HIGH=82. Should I just replace the Orifice tube line and Accumulator? Or is my Evaporator shot?
Edited by jaredwins
added info about engine not running
