Truck has random misfire when hot
- Replies 34
- Views 5.8k
DaveS 16 posts
Mopar1973Man 12 posts
Great work! 3 posts
jlwelding 2 posts
Hi,
Currently I'm dealing with a misfire when hot. Mostly noticeable at idle, lower rpm and slower speeds. It will also make a crackling sound when driving at low rpm. It often hunts for the right idle rpm if I let off the throttle. If I snap the throttle, there's a delay of like 1 second and then it will blow some white smoke like the timing is off. When I go to take off, if I push the throttle too fast at low rpm, there's like a short flat spot in the apps where the truck runs weird and crackles almost like it's choking out.
I have tested and replaced almost all of the fuel related components including injectors 4 times, the pump, and all the sensors except IAT. When cold the IAT reads the same as coolant temp so I don't think that's the problem. I tend to believe the problem is electrical because I did the hot wire to the pump test and the misfire seemed to go away BUT I'm not entirely ruling out some kind of mechanical issue either. I did reset the valves and a few were not quite right so that did help some but I can still hear the rough running when it's warmed up. There is no air in the fuel, per the clear hose test. The apps signal appears to hold steady on an analog meter. I have done the WT wiring mod on my truck, the alternator shows almost no noise and just to be sure I completely disconnected it. Nothing helped.
Until recently, there have been no codes. It finally threw a PO122. So currently I'm doing the testing in Mopar man's article for that code. Everything checked out until step #6, which is to check for continuity between the blue/white wire on the apps harness connector and pin 31 on the ecm connector. Is there supposed to be a certain level of ohms there instead of just continuity? There is continuity there, if I'm doing it right that is. Both harnesses disconnected, key off.
My question is this. In the article you state that if there is continuity, the ecm needs to be replaced. That's where it gets a little confusing. It states if there is no continuity, repair the open. If there's continuity, replace the ecm. So it sounds as if either way it's a problem. Earlier I swapped the ecm with my brother's truck, which is exactly the same as mine. It didn't change a thing. BTW, I'm also running a timbo apps which is probably 4 yrs old now. I had also swapped the apps with my brother's with the same result.
I hope you can help.
Thanks, Dave
