Timing Cover
Ive got the fan out and shroud off while im installing new dampener and figured while Im there might as well fix the leak. Im not sure if the timing cover has a gasket or if just sealant. Anyone give me a heads up. Thanks
  • Replies 3
  • Views 1.2k
    Gear case is just grey silicone. Your going to need a front crank seal. I've done several gear case reseal, grey silicone works really well and normally last quite a while.
  • You should do the KDP while you’re in there.
