- Replies 9
- Views 2.9k
Me78569 3 posts
Andyba20 2 posts
Hutch24v 2 posts
dieselautopower 1 post
Well we have hit 60,000 miles in the 4th gen. Replaced the oil and fuel filters.
I have on order from @dieselautopower the Banks big horn intake elbow / grid delete plate. This will prevent the grid heater bolt from falling into the motor if the bolt fails does fail. Not typically a fan on Banks due to $$$, but their design allows me to not need a tune and it looks well done so it is what it is. The OEM grid heater is replaced with an ford 7.3 / duramax 6.6 Intake air heater in the elbow. It draws less amps and work work as well as stock, but if it isn't good enough I will just weld in a 2nd heater and daisy chain.
also need to get some shocks ordered to replace the stockers as I am sure they are getting worn.
To date I have replaced nothing other than oil and filters and it has been a great truck.
