Huge puddle question
Hey guys, being from Canada BC, the floods have been pretty bad and i had to drive through some pretty deep stuff for about a whole minute. i made sure to go slow. it wasnt up to the bottom of my doors but it was pretty high regardless. i pulled my air filter off to see if there was any water, and it was pretty damp and some water droplets, but nothing crazy. is this something to worry about. it was about up to 3/4 of my tires. im all stock aswell
thanks guys
Just now, DodgeRam2002 said:
Hey guys, being from Canada BC, the floods have been pretty bad and i had to drive through some pretty deep stuff for about a whole minute. i made sure to go slow. it wasnt up to the bottom of my doors but it was pretty high regardless. i pulled my air filter off to see if there was any water, and it was pretty damp and some water droplets, but nothing crazy. is this something to worry about. it was about up to 3/4 of my tires. im all stock aswell disregard my sig, thats my old truck
thanks guys
  • Replies 4
  • Views 1.3k
Check that the vent hoses on the axles are there and no water infiltrated the axle housings and contaminated the oil.
awesome ill probably end up changing the diff oils just to be safe. on another note would i have to worry about any water seeping into my intercooler boots,oil pan or trans pan?i had some small leaks i believe but nothing crazy. thanks
I've managed once to get water in the front differential from just running deep snow and mushy snow. Yeah its possible to draw in water in the differentials. Double check the vent hose to be sure they are as high up as possible. Just pull the plugs and dip a finger to check if you have a milkshake in the differentials.
No, I wouldn't worry about those things at all.
