Good Source for Re-manufactured 47RE Automatic Transmission
My brother-in-law in Crescent City, CA has a 2002 4wd Cummins 2500 truck that has logged 175,000 miles.  The stock automatic transmission has failed l- no second gear.  I don't have any real details of the exact failure.  The truck is still stock - no tuner and original injectors.
The truck occasionally tows a very heavy 5th wheel (around 14,000 lbs), usually less than 200 miles round trip two or three times a year.  He has no near future plans of doing anything different.  Sometime down the road he may become a full-time RV-er and he will purchase a truck to match whatever he tows.
I was thinking of a quality rebuild with a lower stall speed converter that would work for his current situation.
Any vendor recommendations would be appreciated along with any helpful suggestions.
Thank you,
- John
  • Replies 8
  • Views 2.2k
Dynamic Transmisson out of Spokane, WA are a reputable builder. They (owner, John) re-built my trans and I'm happy with it. One potential option for your brother in law.
Dynamic Transmisson was my choice when my trans needed rebuilding.  I shipped it from San Diego to his shop.
Thank you @IBMobile, we may be moving forward with this re-builder.  I just talked to my brother-in-law about the Stage II transmission from Dynamic Transmission.  He has determined that he will likely be keeping the truck, so this transmission would be a good match for his needs.
- John
Thanks @Mopar1973Man.  I contacted Dynamic Transmission via email a couple of hours ago.  They seem to be the unanimous "go to" transmission place.
- John
@Tractorman could you clear out your PM box. I was going to PM you but its full.
It is not full
My Inbox shows, "Used 0% messenger storage"  and "storing 5 messages (max 1000)."
So, I am not sure exactly what is going on.
- John
