- Replies 11
- Views 3.4k
Mopar1973Man 5 posts
Unreal Summit 5 posts
Threadzy 1 post
Popular Days
I changed mine out one at a time. Then I retorqued them after they were all installed. I don’t recall having to lift the cab or anything extra to replace the back studs. It’s not said to do it in the
Easy I used a floor jack and a 2x6 board. I placed the board under the cowl and jack it up about 1/2 inch and the stud fell in on its own.
I'm running 25* BTDC at 2,000 RPMs currently with my tune and head studs. But the trick is my high timing will only occur when the boost is below 5 PSI. Typical at 55 MPH is 0 to 1 PSI boost and then
Going to be putting headstuds in this week coming up. Any advice? Easy way to get the back head bolt out and stud in? Anyone against the one by one method?? Any advice at all is welcome.
