1999 5.9 cummins crank but no start and no tach P0522
- Replies 21
- Views 12.4k
bshoemaker83 9 posts
Mopar1973Man 8 posts
IBMobile 2 posts
5akman 1 post
Below is a High Line CTM. You can see the two connection points on it. If yours only has one connection point then it doesn't have the Vehicle Theft Security System (VTSS).
How to test... Press the trip button down and turn the key on but don't start. Now when the word "Chec" shows up in the odometer display release the trip button it will test all the functi
Truck currently does not start I can disconnect one data link wire from vp and it will fire up and run. Currently it has dtc P0523 oil pressure sensor voltage high code.
