P0121, P0237, P0234, P1689,p0236 all at once.
- Replies 12
- Views 2.7k
whuhta71 5 posts
Tractorman 4 posts
Mopar1973Man 2 posts
Max Tune 1 post
I would do the W-T ground wiring mod first and then recheck the alternator for stray AC voltage. Also, I think the test should be done after the grid heaters stop their post cycling, otherwise you c
Hey sorry for not updating this post last night, wrapped up around 4 am too tired to think straight. I did end up going back through everything and redid my connections and hooked it up again, don’t
🤣😂🤣😂🤣😂🤣😂 Here ya go.....😂🤣😂🤣😂🤣😂🤣 https://www.cumminsforum.com/threads/auto-trans-erratic-shift-solved-with-engine-oil-change.2585351/#post-29836667
Had all 5 of these codes pop up at once after changing all of my better connections while trying to figure out my electrical issues. I’ve been dealing with a p0121 off and on for 3-4 months, replaced my APPS, dead pedal came back 3 wks later. Coincidentally my trans (auto) started not going into gear in drive or reverse until I rev up to about 1k rpm’s. I did the BD diesel noise isolator and for a few days it drove perfectly with zero shifting issues or dead pedal. Then started having overboost codes and then the truck randomly died twice. Replaced batteries and redid connections and triple checked the connections, and now I have those 5 codes. Thinking ECM going out due to alternator? Thoughts?
And how would I test my ecm to find out?
