Posted October 3, 20231 yr I just need the bushings for a 2000, 3500. I'm not trusting what I am seeing online. Where would you guys purchase?
October 4, 20231 yr I bought two different descriptions of bushings from amazon. Neither worked. Heated them water etc. For my 99 2500. Went to Napa. They had a assortment pack. I believe they were for Ford. They fit perfectly.
October 4, 20231 yr Author 10 hours ago, Rocko said: I bought two different descriptions of bushings from amazon. Neither worked. Heated them water etc. For my 99 2500. Went to Napa. They had a assortment pack. I believe they were for Ford. They fit perfectly. The shop that was doing the work on my truck got a DORMAN replacement and it didn't work at all. The kicker is I'll find something specifically listed as a replacement for a 2000 dodge but then when you look in the details it is for 2002 to 2005 or something like that.
October 4, 20231 yr Author SO... I broke down and called a local Dodge dealer... they looked it up for me. They had to look from the transfer case side to even get the grommet part number... but with it I was able to find THIS. https://torqueking.com/product/10589/qu10589-transfer-case-shift-linkage-grommet-or-bushing-for-dodge/?dfw_tracker=64486-3171&cmp_id=17998788702&adg_id=&kwd=&device=c&gclid=Cj0KCQjwmvSoBhDOARIsAK6aV7jyF49S_6OWbRI5zVCtBeIdLBKnFGmzPpYmHND-6rXCilird-QUf90aAhtrEALw_wcB
October 9, 20231 yr Owner Just a heads up I've got the part books here on the website so you can look up factory part numbers for your truck they are located here... https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/
October 9, 20231 yr Owner All member need to surf the site being there is so much here on the site for info.
