For CajFlynn about Scangauge II
Hey guys... I know you wanted to see the SGII and how I mounted... post-2-138698171457_thumb.jpgpost-2-138698171464_thumb.jpg
  • Replies 4
  • Views 2.4k
That looks great. Can you make me 2 of those? How is it attached under the bezel?
lol it looks better than mine....i used industrial grade velcro and stuck it to the bezel above the ash tray.... then used the ash tray to hold all the extra cable and then used another peice on the bottom to hold the ash tray closed up to the bottom of the scan gauge... doesnt look bad but not as sexy as a real bracket :thumbup2: dont laugh to hard lol its what i had on hand :lmao:
Ummm... Be my guest... I all I did was get lucky on my mounting... Behind the bezel is a signal screw for the pouch below and basically bent a L bracket and drilled a hole. My problem was my hole was a bit off and required tweaking to get the SG to sit tight. You don't want to see the other side of that braket... It a road sign still with its reflective markings... :lmao2::lmao:
ummm... Be my guest... I all i did was get lucky on my mounting... Behind the bezel is a signal screw for the pouch below and basically bent a l bracket and drilled a hole. My problem was my hole was a bit off and required tweaking to get the sg to sit tight. You don't want to see the other side of that braket... It a road sign still with its reflective markings... :lmao2::lmao:
that's sweet!!!!
