- Replies 27
- Views 13k
Mopar1973Man 7 posts
hayman75 6 posts
Doubletrouble 4 posts
rejracer 4 posts
I haven't settled on a good position for all the power cables. As I said the cable to the starter was a bit long so I had to bring it up and around. Ground lines are all good, much larger cables.
While your into all the wiring, if you have not yet done the w-t ground mod it would be a good time.
I have all this from the kit. I think I'm going to for it and do them all. Has there been a consensus on the need for a fusible link or fuse when rerouting the charge lead?
I am in the throes of replacing the crank seal, tappet cover gasket, radiator, and intercooler. With the good access, and since I plan to keep this truck, I figured I'd replace the battery cables. No real issue just tired of the corrosion and poor stock terminals. I ordered a nice pair from K Suspension but the install instructions leave a lot to be desired. Information is limited from other sources, anyone every tackled this job? One part that seems daunting is the many sensors that share the wire loom with the power cable going to the starter. Getting that apart and keeping it all straight must be a challenge. Any advice is appreciated.
2001 2500 Quad Cab - Bone stock
