- Replies 13
- Views 2.1k
PilotHouse2500 7 posts
Tractorman 4 posts
IBMobile 1 post
Royal Squire 1 post
Where I'm currently sitting...thoughts? 1" of depth added.
Yah cut out a section and planning a fill panel to weld in. Still plan on a wrap and heat shield. Top pic is the fabbed fill panel, second I'd cut out and third is that panel set in the c
OK great, I'll finish fit up and weld this week. Hammer formed on a wood bock, frame rail on my 51 COE (unstarted future 6bt conversion project), and two pieces of steel I have to help m
In my project I finally found a 90° down part that fits. The gap between the 90 and the firewall is about 0.700". If I wrap the 90 will that be enough of a heat reduction so I don't discolor the paint (or damage it) for that gap? Or do I need to create a bigger space behind that?
