Auxilary tank install, anyone have one????
- Replies 7
- Views 2.4k
Doubletrouble 3 posts
Mopar1973Man 1 post
QuadRunnerJake 1 post
5akman 1 post
Look up dual tank control valves. You should be able to get either a manual or electromechanical valve for controlling fuel on a stock set up. Now AirDog / FASS is tougher with 1/2 inch lines.
So I came across a deal on a 90 gallon L shaped auxilary fuel tank to mount in the bed of the truck. It's used but still good. I have never had one nor mounted one in a truck. I was wondering if someone on here has had one and mounted it. Any tips on how to do so?
Also, if you have one are you gravity feeding it to the main tank or did you install an inline fuel pump? I have a small inline pump on the shelf and was thinking about using it with this tank to fill the main tank with a flip of a switch. Thoughts??
I'll be getting the tank sometime over the weekend so I'll post up pics once I have it.
Thanks for any input.
