Finally have gauges!!
- Replies 5
- Views 2k
Mopar1973Man 2 posts
AD25 2 posts
Doubletrouble 1 post
It seems to work well. The lowest the egt will go is 200° so it starts there. The fuel pressure shows 19-20psi at idle, driving diwn the road at various speeds it levels out about 17psi, ful throttle
Without a boost fooler. The fuel rate would be cut above 20 PSI because it's a known error in the stock system which should toss a P0234 code.
So I was finally able to make the time to install my 3 in 1 gauges from gloshift. Before you hate on gloshift, this was a gift from my daughter for Christmas.
Took a little while to get it done, it was rather warm today (89°F / real feel was 95°F). I did get it finished though. I mounted the gauge in the supplied pod above the instrument cluster for easy viewing.
The needle shows boost, in the small LCD screen is displays the exhaust gas temp and the fuel pressure.
