- Replies 16
- Views 2k
YeaImDylan 7 posts
Mopar1973Man 5 posts
Tractorman 4 posts
As long as I keep my engine load below 20% I'm on super high timing (25° to 27° BTDC @ 65 MPH) and there are no real expanding gases and EGT's are less than 450℉ to provide to the turbo but yes during
Hey all, need urgent help. It’s been awhile since I’ve posted which means things have been pretty good.. just got home and a few blocks away I saw a little blue smoke. Nothing at idle but saw a good amount of oil blew out the crank case vent, about to check oil level now as oil pressure was lower than normal at idle. I figure it got burned on the exhaust cuz the top valve cover had oil from I’m assuming the fan blowing oil everywhere. Freaking out because I’m supposed to be towing a 10k trailer on Wednesday. Gonna check vacuum lines and make sure none came disconnected and whatnot as well as check oil level. Oil is about to maybe hit 5k mark.
