1997 2500 T Steering swap
- Replies 9
- Views 2.4k
Mopar1973Man 4 posts
Tractorman 2 posts
RecoilFreak 2 posts
Doubletrouble 1 post
With stock sized / near stock sized tires and stock suspension height - I say no. I am not sure that there would be any benefit even with bigger tires and raised suspension. I installed a steering b
I agree, the concept seems sound. If the added bearing is centered and well anchored, then it should be beneficial. It seems like you may have the equipment and the skills to do that. Let us know h
Sadly all wear issues are results of lift kits and large tires either T or Y steering will still wear quickly because neither set up will support wide tire or lift kits. Sadly this mod will not stop w
Greetings! I know this has been discussed several times here - I have read all that I can find, but didn't find the answer to my question. My ball joints are worn out, and I would like to convert to a T steering setup. I know plenty of guys have said their Y steering is just fine if setup properly with no lift or big/wide tires. I have a lift and big/wide tires. According to what I have read, the newer style T setup will bolt on, but the taper is different in the knuckles and the pitman arm. I have read there is an HD T setup for 98-99 trucks that will bolt in and have the correct taper, but I cannot find a complete setup like has been mentioned here before. Does anyone know what the taper is if I want to ream the holes? What are the options here? I don't want to spend Synergy or Apex money - just stock style parts. The truck came with an upgraded track bar and mount, so that's not necessary. Is the steering gearbox brace worth the money? Thanks.
