- Replies 10
- Views 3.4k
Krlspokane12 5 posts
Tractorman 3 posts
JAG1 2 posts
Hey Guys,
I really need your help on this one. I have been chasing an intermittent dead pedal and hesitation issue and I'm not sure what could be causing it. It does not happen all of the time, there will be days that i drive the truck and it doesn't happen at all and other days where it happens multiple times. It doesn't matter if the engine is warm or cold either. It usually happens under acceleration, but it has happened while cruising. I will go to accelerate from a light and nothing happens when i push the pedal for about 2 seconds and then it will kinda sputter and then accelerate like normal. I put a new VP on the truck in July and after talking with Mastertech diesel here in Boise, they thought my new pump might be going bad already so i took it back to them on Monday to be tested and it passed, so i know that is not the issue. There are also no codes or check engine light. All of the following has been done to the truck. so I'm not sure if I'm chasing an electrical gremlin or the new ECM is beginning to fail. Any insights or trouble shooting help will be greatly appreciated as i don't just want to start throwing money at random things hoping it fixes the problem
New batteries in April
New alternator last year
New battery cables
New ECM in 2021
New OEM MAP sensor in 2022
New OEM cam sensor in 2021
New VP in July 2024
New Timbo APPS last month
WT wire mod
Air dog 100 and 14psi of constant fuel pressure
