24v weird throttle after nv4500 swap.
02 24v i swapped 5spd in place of the auto.  Im still using auto ecm/pcm with no check engine lights. Occasionally the trans temp light stays on for a few min then shuts off. The throttle response is weird and Occasionally wont rev past 19-2000rpm. Apps checked out.  I've been using the search function and have found that i need ecm/pcm reflashed? Does anyone know if this can be accomplished with a tuner? (Or do i need to find a manual ecm/pcm.)If so any recommendations? I already tried calling a dealer. They had absolutely no idea what I was talking about. Any advice is appreciated.
Edited by Bob1983
  • Replies 10
  • Views 1.4k
Give Auto Computer Specialist a call.  They should be able to help you with your needs.
Phone Number: (954) 513-8359
I had sent a email waiting for a response.  I'd like to figure out a way to do it without my truck being down. It's my only truck at the moment
Sadly you have to send the ECM in for repairs and maybe about 5 to 7 days on average to get it repaired.
I had a job where I had the client send both PCM and ECM to be refreshed for manual and everything worked out right.
I did more searching last night and seen that the smarty is able to do what I need(i think) . I sent a email to Mads.
I'm thinking this is the way I'm gonna go. Can't really have my truck down this seems like a reasonable solution.
Problem what are you going to to about the PCM software? Remember that the Smarty will reprogram the ECM but does zero for the PCM on removing transmission controls going from Auto to Manual.
I took a screenshot of the email I received.  Screenshot_20241007_202138_Gmail.jpg.1011357e98e8a9f812df304ac3ba16f1.jpg
