Headlights, tail lights, and turn signals blink
I have a 2004 crew cab short box that when I start the headlights, tail lights, and blinkers all blink for a few minutes. Any idea what the cause is?
  • Replies 21
  • Views 6.2k
    Give Module masters a call in Moscow Idaho.   https://mopar1973man.com/vendor.htm/vendor/module-master-r8/
    Chipped key required you can't start a 3rd Gen truck without chipped key near the ignition lock. Thor is that way and without the chipped key it will start and run a very short time like 2 to 5 second
  • That's what I'm kinda trying to avoid. Got friends with software on laptop and connections to reprogram auto computers. But if it needs fixing prior to that I'm not sure if I'm able to source the part
