Archoil Friction Modifier
20 years ago or how ever long ago, long time. I started running 2 stroke oil after reading Michael's research and never looked back. I keep hearing this Archoil lubricant and wanted to see if there was any talk about it. I cant seem to find the write up on it from years ago. So Im here picking brains on the subject. What do y'all know?
  • Replies 2
  • Views 997
I’ve never added any additive to my fuel tank in 24 years. I have used that Cummins approved Diesel Kleen occasionally but never noticed a difference.
I think a lot of that stuff is snake oil. The biggest hurdle in diesel fuel is water and as long as you can filter that out your gold.
I’ve lived in some harsh, cold climates and never had a freeze/gelling issue either.
Out here lubricity is low. Bosch VP44 require 460 HFRR or lower. Most all fuel is roughly 520 HFRR. Might read about the fuel additives in the article database.
