Track Bar
  • Replies 22
  • Views 4.9k
  • That looks like cheap Chinese knockoff crap that break under any kind of stress. Don’t trust your life to $119.   I made my own. I used a 07 Power Wagon bar (16mm) and cut it in two and had
  • Also, without a dense rubber bushing on one end of the track bar, every  pulse of energy generated from the road will transfer through the track bar to the frame, then the body, then to you.  I don't
  • Doubletrouble
    Doubletrouble
    The last one I put on was from napa, they offer a couple. Sorry, I don't have the part number handy though.
Solved by Tractorman
You're welcome.
I think you set your toe-in a bit aggressive.  You will likely wear the outside edge of the front tires and the truck won't handle as well as it should, especially going into and coming out of curves.  With the Y type steering linkage, the toe-in should very slightly inward - no more than 1/16th inch.  With T-type steering the recommendation is zero toe-in.  It appears that you have the Y-type steering.
Good job marking the jam nut positions.
- John
10 minutes ago, Tractorman said:
You're welcome.
- John
Good to know. I’ll readjust it tomorrow.
