- Replies 5
- Views 3.3k
Mopar1973Man 2 posts
01_Cummins_4x4 2 posts
IBMobile 1 post
Popular Days
Ram recommends the use of a licensed ATF+4® MS-9602 specification fluid for the NV241, NV243, NV244, NV271, and NV273 type transfer case fluid change. Automatic transmission fluid (ATF) is oft
I've ran both dextron and ATF+4 for transfer case fluids. Beast with 495k miles I've never had any issues including summer heat in Arizona. Only had to reseal the case once.
So I bought a 2012 4x4 1500 with 104k on the clock. Auto trans with electric switch on the dash. Course I looked up the oil and it says to use ATF Here in Tx it gets real hot so I don't think its good to run ATF, what do y'all run?
