Ram air intake
Anyone ever do a ram air intake on our trucks? Bhaf seemed to be a good help and a good friend swore by the ram air intake on his VMAX bike. I feel like it would help in our application (diesel no real air fuel ratio no throttle blade) but I know it's mostly a looks thing on regular gas cars. Just curious if anyone has ever messed with it.
  • Replies 22
  • Views 2.8k
  • Absolutely. And thats pretty much where I'm at. I know my tune is not as good as yours and i know me being an automatic is not helpful (my in park idle engine load is higher then your steady state hig
  • Mopar1973Man
    I can tell you an old member @isx did the math on cold air and hot air and there was a very very small change of amount of moles or molecules of air was in the air system even at boost. So the best i
Solved by yohon
Go to solution
Yup the hope was to try and get air velocity/slightly higher pressure into the turbo for a effect simmilar to compunds. But that turbo draws so much air it's crazy. Everything my small leaf blower pushed out it ate. Doing some reading on altitudes effect on turbo diesels showed that every 1000 feet is 1% loss in power compared to 3% in a N/A system. I know my tune isn't as good as it could be but it's as dialed as I can get it and I wanted to see what else I could find that would help. Thank yall for the help and for reading.
