1689 with HVAC
So I've come to the almighty moparman forums seeking help on an unusual issue I'm having. My truck is heavily modified by the previous owner and I'm constantly having to fix one thing or another and chase things.
So I have 2 issues now 1 of which I believe I know the issue but don't know a good fix.
First issue is I get trans limp mode and a P1689 with no buss on the CCD when turning on the HVAC blower at any speed. Once turned off it goes back to normal. I have taken the ground off for the HVAC controls and the no buss issue also happens without the blower motor running only in face vents or floor vents position.
Looking at wiring diagrams I can't tell where any of the HVAC would cross with CCD modules.
Second issue I'm having is TCC lockup. I have increased line pressures and a DTT box to decrease the voltage to 4.5v all the time. It engages sometimes but not others and the only way I can tell is just by RPM at 60mph. It's 1 tick below 2000rpm with 4.10 ratio rear. I believe maybe the DTT box is bad or the line pressures are too high? What is the TCC lock up algorithm? Sometimes if I left off the pedal and slowly accelerate it will be locked. It's easier to tell if it's locked when I'm towing which is what I use the truck for.
Thank you for any help! I'll provide any info y'all need and hopefully I can get this all figured out!
Edit* forgot to mention I have done the following things to try to fix both issues.
PCM grounded to pass side battery negative
W-T mod
New batteries and alternator
Disconnected a/c relay and compressor( didn't fix so I guess it's not in the a/c circuit)
Edited by ducktape11
Added info
  • Replies 80
  • Views 11.1k
  • I think you could temporarialy wire in a LED lamp to the OR/BK wire from Connector #2, terminal #11 of the PCM. Wire the other side of the LED to ground. The lamp would be on all of the time after t
  • My truck's 3-4 upshift @ ~45mph with light throttle and stock 4:10 diff.
  • I suspect that you may have a poor body to frame ground, or poor body to battery ground. Since the blower motor switch grounding and the data link grounding are in the body ground circuit, a poor bod
Solved by ducktape11
Go to solution
55 minutes ago, Mopar1973Man said:
I need to get home and really look over the wiring maps to see if I can see a reach between these two (CCD Bus and blower motor)
Yea every wiring diagram I've looked through I don't see how the HVAC blower or vent position would mess with the PCM.
Also I drove quite a bit today and I can pick the TC Everytime by letting off the pedal, getting lock, then reapplying pedal. It stays locked and even if I let off all the way or hit the brake disengaging the TC it lock right back up without issue until I downshift to 3rd or lower. That tells me the PCM is not sending the signal for lock because of some parameter in missing...
Were you able to find anything? I'm not too much in a rush I only drive the truck when I tow my camper. I'm stumped at this point because as long as I don't use any HVAC stuff all is well besides the TCC lockup.
Maybe the previous owner has messed up the wiring somehow. It may be worth physically tracing the CCD bus circuit to see if any wiring has been damaged or tapped into.
  • John
  • John
I'll have to take a look and trace the wires from HVAC. Do you know if everything on that circuit is supposed to send 12v to components?
Most of the the HVAC circuit consists of switches in the ground side and there is a blower motor relay and an AC clutch relay as well as a refrigerant low pressure switch. There is a 12 volt supply to the blower motor and the AC clutch relay.
I would be more inclined to trace wires in the CCD bus circuit as those pair of wires can only be connected to components operated within CCD system - nothing else.
Not that Joint Connector #7 is a hub for connecting to many of the CCD components in the system.
  • John
On 4/19/2025 at 9:35 PM, ducktape11 said:
Would AC noise cause no pickup? I don't have the typical symptom of lock/unlock. I need to figure out a way to watch the TCC lockup wire and make sure the PCM is grounding it. My scanner won't give me any transmission live data no matter what I do. Barely any ECU stuff.
Also for the WT mod I put the grounds directly to the battery negative and not the block then the battery so I will do that as well.
The noise can do all sorts of things to your lockup
Should lock up at 48 in normal driving conditions and you should tell a noticeable drop in rpm and driving, not just when towing.
On 4/21/2025 at 12:39 PM, Tractorman said:
I suspect that you may have a poor body to frame ground, or poor body to battery ground. Since the blower motor switch grounding and the data link grounding are in the body ground circuit, a poor body to frame or body / frame to battery ground connection could influence the CCD circuit. Body ground # 200 (located on the driver side inside the cabin) and engine ground # 107 are part of the CCD circuit.
You could temporarily run a jumper cable from the body directly to the battery ground post and then operate the HVAC blower fan to see if the symptoms go away.
  • John
I agree
  • John
I looked at JC7 and unplugged/replugged it in with no changes. The connector seated fine and no burn marks were noted. I tried tracing the twisted CCD wires and I didn't see any torn or broken wires before going into the largest loom ever.
UPDATE
SO I was messing around and I disconnected the blower motor at the connector and was still giving a no buss message. That told me there is a short from the switch to CCD somehow. Then I turned off the HVAC and pulled the blower motor fuse..... NO BUSS MESSAGE! I need to trace the blower motor power circuit because somehow there is power supplied to some CCD component via the blower motor fuse.... The plot thickens...
I pulled out the blower motor fuse and boom no buss... Continued down the line and pulled the relay. Again no buss. Found that putting power through 87 on the fuse to the motor and it's fine. Unplug the blower motor and again no buss. How would a CCD component be powered through the blower motor itself?
Mind you the blower motor is in the office position during all these tests. The blower works fine in all settings. I don't think it is shorted??
Also I remember that turning on my heated mirrors pops the blower motor fuse. I haven't tried using them for over a year because of that and I couldn't figure out the connection between the mirrors and the blower motor. That makes me believe there is a internal short to the HVAC controls??
This is probably clear in your mind, but it is confusing to me. I am not quite sure of what you are saying. Can you write it differently?
Example:
  • Saying "no buss" message can mean something different than saying no buss message.
Maybe you can say, "I am getting the P1689 code "no buss" message"; or "I am no longer getting the P1689 code, "no buss" message."
Thanks,
Edit: I reread your posts and I think I know what you are saying.
  • John
Edited by Tractorman
Example:
Thanks,
  • John
When I say "no buss" I mean the no buss message on the dash. It takes about 6-7sec then odo flashes for a couple seconds. Then no bus shown
Example:
Thanks,
  • John
Do you know exactly where that left kick panel ground for the HVAC is? All the wires down there make general area finds difficult
From the FSM, the blower motor and HVAC controls ground at G200 which looks like a stud behind the kick panel. Hopefully, this illustration can help (unless, of course, you have already seen it).
  • John
  • John
I'll double check that ground since a lot goes through there. Kinda stuck again now though. From the looks of it the blower fuse, relay, and motor are always energized and the HVAC controls module grounds it to make it operate. I'm not sure where to look if unplugging the motor power at the motor causes a no buss message...
Just remember not to grind all the paint off the metal. You'll just make the problem worse. If there is any rust lightly sand then paint the bare metal to stop the rust and let it cure then install the CLEAN nut the nut will cut the paint off the threads and ground perfect.
Why? Because it is super common out here to find the ground wire hanging off the ROTTEN metal and all from people bringing bare metal and not treating the metal so now that rust starts and the ground location is not destroyed. Please treat all the metal surface FIRST make sure its sealed just like the factory did! Then hook your ground up to that freshly painted stud.
I cleaned up g100 and the left kick panel ground with no changes. All I have to go on right now is something in the CCD bus is powered off of the blower circuit somehow.
Remember the PCM is the creator of the CCD Bus. Can you measure the voltages on the CCD Bus+ and CCD Bus- pins to ground and see if the 2.49 and 2.51 voltages can be seen after the modules all stop talking.
Measured from the OBD port pins 3 and 11
2.422v
2.463v
Turning the blower on doesn't change voltage much. Maybe 0.05v at most
