Cracked bodywork at hood hinge
- Replies 5
- Views 1.8k
BFH_Metalworks 3 posts
Mopar1973Man 1 post
LiveOak 1 post
Popular Days
Reinforcement plates. This is how they will ship. Edges cleaned up and smoothed. Sharp edges all knocked off.
For installation, 2 new holes have to be drilled. They need to align with the "channel" in the hinge. The bracket is used as a drill guide. It will fit a 3/8 drill perfect. Reuse the one long bolt in
Anyone else have cracks where the hood hinge bolts to the body? Wanting to gauge interest in a fix I designed for this. It's a 3/16" thick cold rolled steel part. Laser cut and deburred. Quality Hardware to be included. Requires two 3/8" holes to be drilled for each side. The kit will be 2 reinforcement plates, 8 flanged bolts, 4 flanged nuts, 8 washers, and an instruction sheet. I'm thinking $50 plus shipping. I'm need to see what the cheapest flat rate priority mailer I can fit everything into. I didn't post this in the classified section, because I'm not ready to sell. I can't afford to do a bunch of these unless I know that they will actually sell. @Mopar1973Man , if you are interested, I can send you a set of prototypes to review.
