5th gear countershaft needle bearing toast. Do I need it?
- Replies 5
- Views 1.7k
Mopar1973Man 3 posts
greenfun2 2 posts
I put a reman NV4500 in about 3 years ago. It started popping out 5th when letting off, so I removed the tail housing to see what broke. The countershaft 5th gear had alot of play, and the countershaft is grooved really bad where the bearing was sitting. So I need at least a new countershaft. But here's my question: I really need to use the truck before I'll be able to rebuild the transmission. So can I put it back together without the countershaft 5th gear, synchronizer assembly, and shift fork and just run it as a 4 speed for a while? I'm going to measure the end play in the main and countershafts, but they seem ok at first glance.
