Mysterious Knock on VP44 Truck – Need Help! No one can figure this out!
LINK TO THE VIDEO
Hey everyone, sorry for the long read but please God read it and help me!!
I've been dealing with a persistent and frustrating issue on my truck for years, and it's seriously driving me crazy. As a mechanic, it really eats at me that I haven’t been able to solve it. I'm absolutely racking my brain here, and I'm hoping someone can offer some insight I haven’t considered.
The Problem:
My truck has a terrible knock at idle that’s so harsh it literally shakes the inside of the cab. It’s loud and clearly audible, especially in person. The knock doesn’t seem to increase with RPM—it’s primarily noticeable at idle—but it does affect the exhaust note, making it sound choppy (you can hear this clearly in the video I’ll link).
What Makes It Go Away (Temporarily):
Here’s the strange part:
  • If I unplug the VP44 connector and supply 12V power directly to the pump, bypassing the ECU entirely, the knock disappears completely. This made me suspect it’s related to ECU inputs or sensor feedback.
  • Using my scan tool, I can disable ANY injector and then re-enable it. The knock then goes away for about 10 seconds before coming back. During those 10 seconds, the engine runs smooth as butter—no shake, clean exhaust note.
Watch the video and you’ll see what I mean. When I cycle an injector, the knock vanishes for a moment and returns sharply—you’ll especially hear it in the exhaust.
Parts I've Replaced / Things I've Checked:
Here’s what I’ve done so far (this issue predates many of these replacements):
  • Replaced VP44 with a known good used unit from a running truck
  • Replaced crank sensor and verified wiring from ECU to sensor
  • Replaced MAP sensor and verified wiring to ECU
  • Installed brand-new injectors (again, issue existed before this)
  • New alternator (unrelated, but noting for completeness)
  • Installed AirDog Raptor and Beans Diesel sump – fuel pressure is spot on
  • Swapped ECUs from a known good truck – no change
  • Verified APPS wiring and voltage – originally low (~0.34V), adjusted to 0.5V as per MoparMan's advice
  • Checked IAT sensor and verified voltage/wiring to ECU
  • Physically checked the timing marks on the timing gears - all good there.
None of these changes have made a dent in the issue.
Final Thoughts:
This truck is driving me insane. I know the signs are pointing to some sort of input/communication issue, but I’ve tested and replaced so much already that I’m at a loss.
If anyone out there has run into something similar or has suggestions for what to check next, please let me know. I’m open to trying anything at this point.
Thanks in advance!
Note:
I did find a guy on the 2nd gen Facebook page that had the exact same knocking sound and his issue was resolved by replacing the crank sensor. I've done this already, but he did say he replaced his with a cheap amazon one and the issue wasn't fixed, but he tried a name brand one from the part store and it went away.. I'm hesitant to try a new sensor again, but I will buy the Cummins one if y'all think this would fix it!
  • Replies 36
  • Views 6.9k
  • I appreciate the phone call as well. Good to chat with someone that actually knows what they're talking about! I hope to update this next week with a solution! This has been an ongoing thing for years
  • So far I have found nothing! It's not difficult, just time consuming. I have this old power supply that I'm using to help load test the wires! Good to know! Im a cheap *** and prefer to struggle
  • Tractorman
    Tractorman
    I think you have found the issue. I also strongly think that the noise that you have been hearing is mechanical. I think the noise faded away when you disabled one cylinder and when you ran the en
Most Helpful Posts
  • Tractorman
    Tractorman
    First, I must commend you for a well written description of the symptoms of a problem that you are trying to resolve. People rarely give that attention to detail when describing a symptom or communic
Let me think on this more. I'll sleep on this and see if I can figure another test to get a clue.
Oh. How about error codes? Still the same?
The only code is the lift pump code and the oil pressure sensor code for the faulty oil pressure sensor ( the lift pump code has been there for years. I have an in tank factory conversion that i bypassed for my raptor lift pump, so the plug is disconnected causing the code)
Took some time after work today to try to figure out whats going on with the truck.. still no real diagnosis now. I noticed when I start the truck it runs normally for about 7-10 seconds before it starts idling weird and misfiring. Here's a VIDEO of what its doing now. I'm about this 🤏close to just selling it like it sits. I'm frankly tired of working on it and even more tired of spending money. I'm still not getting any codes... no real path to follow now.
It's electronic based issue in my opinion.
VP44
ECM
...but ECM would throw a code. VP44 has been known for problems without setting a code. Strange like it's skipping a cylinder like injector drop test on a DRBIII tool.
Sort of an update here: I found the lift pump wiring pulled out of the backside of the connector... I don't know when that happened.. Maybe when I was reinstalling the harness? I'm going to get a new connector for it. Basically the truck was running like **** because there was NO LIFT PUMP. Hope the little bit of idling I did with it didn't hurt the VP!
  • 8 months later...
UPDATE:
I found, in the depths of another forum, someone with the same exact issue as me. Here is a LINK to their video they posted 16 years ago! They went down the same exact rabbit hole I did and ultimately ended up pulling the oil pan to find a damaged tone ring. I inspected my tone ring through the CKP sensor hole but its a very small area and I wasn't able to really good a good look at it. I'm going to pull the oil pan tomorrow and give it a real inspection. I HOPE I find an issue with the tone ring so that I can finally put this to rest!
Good to hear back from you. I am hoping that you are on the right path and that you have finally found a solution to your forever lasting symptoms.
Of course, you know that when this is fixed, you will constantly be hearing random phantom ticking noises for at least six months - then you can finally relax.
  • John
HUGE MEGA ULTRA UPDATE:
LINK TO VIDEO
I have finally found the issue, I think! I had time today to pull the pan off (btw, this can be done on a 2WD without removing the engine, maybe I'll do a write up on it). After removing the pan, I turned the engine over by hand to visually inspect the crankshaft tone ring. Now, I should say that I inspected this ring before but only with an inspection camera through the sensor hole and did not see any issues. The sensor also is not damaged or nicked in anyway to indicate any issues with the ring. The tone ring is a 2 piece ring. There are 5 bolts that hold the ring in place. 3 bolts on the large piece and 2 on the smaller piece of the ring. Well, one of the bolts on the smaller ring has backed out completely and is missing. The other remaining bolt on the smaller ring is bent. I can literally move more than half of the tone ring by hand! You would think that a ring this loose would cause a CEL for CAM/CRANK correlation codes or something, but I guess not. It must be just off enough to cause a wild timing scatter but just on enough to be within "spec" of the CEL condition. I ordered a new (used but in good shape) tone ring and all 5 bolts. I'm going to remove my ring this weekend and install the new one and LOCTITE THE CRAP out of the new bolts.
I will post a follow up update the moment I get the truck running!
FINGERS CROSSED THIS FIXES MY ISSUE!
I also strongly think that the noise that you have been hearing is mechanical. I think the noise faded away when you disabled one cylinder and when you ran the engine with the ECM out of the loop because you changed the cadence or resonance of the engine in motion, thus changing the movement behavior of the loose tone ring piece. This would also explain why no code was set for the crankshaft sensor and why the engine performed as it should - not a timing issue.
I think your perseverance has paid off. Great job on your part!
Post a photo the tone ring.
  • John
PROBLEM SOLVED:
LINK TO VIDEO
Well guys, I did some digging in the oil pan today and found the missing bolt. I pulled all of the tone ring bolts out, threw some blue loctite on them and buttoned everything back up. Sure enough the knock is gone! It sounds like a normal 24v again! FINALLY! I've been chasing this issue since 2021! Thank you to everyone who offered advice or suggestions! I'm so thrilled I get to close this chapter. I hope if anyone else has similar symptoms in the future that they find this post and can solve their issue and not spend near as much time and money as I have going through this truck.
Congratulations!!! Are you feeling euphoric? I have been waiting for you post. Now that your truck has thoroughly tested you and you won, the truck should behave itself for the rest of its life under your ownership.
  • John
  • John
Thank you! Yes I am definitely feeling the high! With as much time, energy and money I've put into this thing, it better be problem free for a while 🤣. I will say, I was doing a quick inspection while I had the pan off and the crank, rods and cam look brand new still at 200k miles! No oil buildup, etc! The cam lobes looked perfect too!
See ya there lol! I guess now that it runs right I have to actually care about it, so i gave it it's first bath in a LONG time lol.
Good lookin' truck ya got there.
406,000 on my 2002, 4WD 6 spd (bought it new in October, 2001)
  • John
Edited by Tractorman
