Help me build the perfect motor
- Replies 30
- Views 2.4k
yohon 14 posts
Mopar1973Man 9 posts
IBMobile 3 posts
Mace 2 posts
That is the first ray of sunshine I have heard. Is love to tighten this transmission up but for sure dont want to grenade the transmission. I'll call power driven/dap and see what I can do
Basically, the pump section pulls out of the reservoir, and there is a large o-ring. As for the pump vanes, I've never opened up. Rest is just o-rings. Be sure you can get the o-rings first before ope
Absolutely
Found out today I have a 2 piece head bolt. So truck is parked for now and i found a new long block for 3k. Ideally if im going to swap the motor I want to build it prior to. All supporting mods aside whats the best set up for a vp44 truck? I know we tap out around 700 hp which suits me fine. I think I would like to do a cam and cnc ported head. I dont plan on exceeding 3500 rpm so do I need valve springs? Fire ring or o ring ( compunds are probably in the future) what else am I missing should I step up to 14mm head studs?
