- Replies 9
- Views 1.6k
Sycostang67 4 posts
Mopar1973Man 3 posts
Tractorman 2 posts
If I am understanding correctly, the engine died because the lift pump was not operating. If this is true, then one of two things could be happening: The engine died because the VP44 internal vane pum
When I started my truck the first time with the new ECM the fuel pressure was at its normal range of 14-15psi. After I shut the truck off I replaced a wire on my switch box and accidentally knocked a wire from the fuel pump relay. When I started it again I noticed I had zero pressure. Thinking I could figure it out quickly, the truck ran out of fuel. Once it was sorted the truck obviously wouldn’t start. I loosened the fass filter and ran the pump until it gushed and then retightened. I then cracked 2 injectors and cranked until they bubbled out fuel. The truck runs but now it takes a a few extra seconds of cranking when cold to start and the fuel pressure gauge doesn’t read until a few seconds after it has started. My pressure is now at 18-19psi. The truck runs and drives fine, not sure what to do.
