Good afternoon, I put a titanium fass lift pump along with a Fleece sureflo sending unit on my 2001 pickup about a year and a half ago. It’s been flawless for a few thousand miles. I had been noticing some slow starts when warm. Not bad just a few more revolutions than what was normal. I put some NAPA cross referenced fuel filters on because I didn’t have FASS replacements and didn’t have the time to wait . I started to take a trip recently and fuel pressure dropped significantly. I got the truck home and parked it for a month . I wasn’t real confident about the NAPA filters so i replaced with the direct replacement FASS filters. Test drove the truck for an hour or so and all seemed fine. Today it did the same thing again. I had gotten 17-19 psi at idle and 15-17 WOT. Today it dropped to 15 idle and drops significantly at WOT.
I talked to tech support at FASS and he mentioned something about a valve in the VP 44 might be a problem. Now when I turn the key on PSI jumps to 17 and drops to zero momentarily when I start the pick up. I’m in the process of putting a mechanical gauge in line to verify that the brand new auto meter pillar gauges are not the problem. Does this sound like a VP44 problem? Truck only has a 160000 miles, but I assume VP44 and everything beyond is original equipment .
Thanks, Kevin
Edited by kbf98520
  • Replies 4
  • Views 23
    I believe you're experiencing a suction side air leak. Double-check the suction line side fittings, make sure they are snug and clean in the fittings. Let me know what type of hardware you're using.
  • Tractorman
    Tractorman
    The tech is probably referring to the 14 psi overflow valve in the VP44 injection pump. This pressure control valve is very reliable and I am almost certain it is not your problem. People have replace
The other part could be that you have a return line leak? Like, possibly a crossover o-ring issue or maybe injector o-ting. Sounds weird, but I've done a head gasket after the head came back, cleaned the baked injector o-rings would weep air in, allowing the system to drain, making a hard start. I've see nthis with crossover tube o-rings as well. Make sure to double-check the return tee in the rear of the engine; it might be weeping air into the system while parked.
Ok, the return line wouldn’t cause the low pressure while running would it
Everything is JIC and I beiieve everything downstream of VP44 is stock
The tech is probably referring to the 14 psi overflow valve in the VP44 injection pump. This pressure control valve is very reliable and I am almost certain it is not your problem. People have replaced this valve because of not understanding how the fuel system works, and then found after replacement, their symptoms didn't change.
Even if the overflow valve failed (as in opening at a lower pressure), it would have little or no effect on lift pump pressure. All fuel that enters the VP44 must pass through in internal fixed displacement vane pump. This pump is regulated at 100 - 300 psi depending on engine rpm and engine load. Because the internal vane pump is fixed displacement, additional fuel cannot be forced through it regardless of lift pump pressure.
Both Airdog and FASS lift pumps use a ball and spring check valve to regulate fuel pressure by recirculating any fuel that is not being used by the injectors and the VP44 cooling system. If the lift pumps are high volume pumps (which yours probably is), then a lot of fuel has to recirculate, in fact more fuel recirculates than gets used. The pressure control valves on these lift pumps are usually not of high quality and the ball and seat can take a beating, which can cause symptoms that you are experiencing. I am surprised that the Tech didn't mention this.
I would be looking at two possibilities for low / erratic lift pump pressure.
  • Check the condition of the ball, spring, and seat in the lift pump.
  • Check for any restriction / leaks in the low pressure fuel supply. Pay special attention to the suction fuel lines from inside the fuel tank to the lift pump.
Many people that have observed erratic lift pump pressure have stretched the spring in the lift pump's pressure regulating valve for a bit more tension. For some it gave desired results.
  • John
Edited by Tractorman
  • John
Lift pump has a lifetime warranty. Hopefully I get it narrowed down tomorrow.
I have not even looked for the tee in the back of the head yet as I have not seen any evidence of fuel leaking from there. What’s the best way to access that tee?
