Engine sometimes stalls when put into gear
- Replies 11
- Views 410
Mopar1973Man 5 posts
Snoxxy 5 posts
Tractorman 1 post
Popular Days
Long posts are appreciated - especially when they are informative - like yours. I'm leaning toward your new low-stall converter triggering this issue. A stock converter has a stall speed of about 2,
This is pretty accurate. One of my other cars is an Evo with a stroker engine that was built when I was still stationed in Japan. The builder told me that with the clearances, i need to run 20w50 oil
I show up... The member who pops up in this type of stalling issue is @pepsi71ocean he had a DTT transmission built and had a similar issue with stalling. It turns out that the torque converter is t
Greetings,
Long time listener, firl time caller here.
TLDR: When cold, the transmission sometimes stalls the engine, but only once. Trans new - Firepunk, billet torque converter.
EDIT - No Codes present
Video with the issue posted on bottom of this post.
So I recently moved back to the states from a long stint living overseas, and I picked up a 99 4x4 A/T truck. Power wise, the truck is completely stock apart from an Edge EZ the PO installed. Everything was great, except the trans would not lockup in O/D. Following many suggeestions from here that could have an effect on the lockup, I realized this was a torque converter issue.
I ended up deciding to bite the bullet and have a built trans put in, and had Firepunk DIesel install one of their stage 1 transmissions, which comes with a billet single disc torque converter.
The trans works great, OD locks up super hard, have about 3500 miles on it so far, and i have no qualms with how it shifts or how it behaves.
Here is my issue. After christmas, drove to northern Ohio (I currently live in southern GA), and of course it was quite a bit colder. The truck sat overnight and it got pretty cold, as it dropped to roughly 15f. When starting it, I let it run for about 5 minutes, and when pulling it into reverse, the engine stalled out. This was new to me. once putting the truck back into P, and trying again, it worked fine.
This has happened a few times, and I even reached out to firepunk about this, and they thoughts maybe my PCM commands lockup and that this causes the engine to stall out. I made a test circuit that lights up a LED whenever the PCM commands lockup. With this I was able to prove lockup is working as required.
I googled this a bunch, and this is apparently a relatively known issue on VP44 trucks, for the injection pump can't cope fast enough with the added load of the lower stall?
I have since started to raise rpm to about 1000 when putting it into gear, essentially power braking it, and this totally works, but I feel like there should be a better solution.
The stall is also not extremely abrupt, it really feels more like a car that has the emergency brake pulled, and someone releases the clutch while in gear. The engine loads and dies, it happens within about a second.
Further, if the truck happened to stall due to this, once restarted, it powers through it.
I am all ears if the smart folk in here have some insight into this, as the approach of "thats just how a VP44 is" doesn't sit right with me.
Thanks in advance, and sorry for the long post, I try to be descriptive.
Phil
P.S.:
I was unable to attach a video, so I just threw it on youtube as an unlisted video.
Edited by Snoxxy
added information - cleaned up formatting
