- Replies 7
- Views 377
Mopar1973Man 3 posts
kbf98520 3 posts
01_Cummins_4x4 1 post
Popular Days
Basically, in a nutshell, the alternator charge line is hooked to the passenger side battery. The engine grounds for the ECM and VP44 are separated and relocated to the driver's side battery, so the g
No. Just make sure to carry extra fuses. Not just one either. I opted for the resettable circuit breaker and easy to just toggle the reset arm.
I’m pretty sure this has been covered, but I can’t find it. So the way I understand this the alternator feed into the PDC is eliminated. There is a 140 amp fusible link between the two hot leads going into the PDC what is the purpose of this? Do I need to bring that second lead going into the PDC to the driver side battery or is this not needed?
