Predictable Stalling
- Replies 7
- Views 638
Tractorman 3 posts
Jordan_ 3 posts
Mopar1973Man 1 post
Popular Days
Good information on your first post; however, I am not sure what a "hiccup" means - could you elaborate on that description a bit more? In the meantime I will refer to "hiccup" as a symptom. If I
Good idea posting the video. I listened to it several times. To me, it sounds as if the engine fueling is being momentarily switched off (no fueling, falling rpm) and then a split second later switc
One more thing to possibly verify, if you haven't done so already. Temporarily jumper an LED test bulb to the wire at pin #7 at the VP44 (the 12 volt supply from the fuel pump relay). This bulb shoul
Need some help. I have an issue with my truck where it will progressively hiccup then stall. Truck is a 99' 2500 auto 4wd shortbed
If I start the truck and change to gear, after 4 minutes truck will start hiccupping and it will hiccup in intervals of exactly 5.4 seconds where they progressively get worse. After about a dozen or so it's bad enough that it's able to stall.
If I start and stay in idle, wait 5 minutes, change to gear, it will immediately stall.
The predictability is truck start -> 5 minutes pass -> will stall.
However:
I can circumvent it by applying and holding throttle for about 5-10 seconds. If I do this before, during, or after that hiccupping cycle starts, I can drive like normal for however long I want with no issues. But once the truck is shut off, depending how long I wait to start the truck again, it will either immediately stall or go back to square one. The sooner I start the truck, the sooner the cycle starts. Overnight, the hiccupping will start after 4 minutes.
So, this issue happened 3 years ago as well. Now is the time to mention I had, and have again, a P0216 code. Last time, after I changed the factory APPS sensor to the WELLS, everything ran smoothly and the code went away and all issues went away for over 2 years.
Currently, the WELLS APPS is set to .533v. The original was labeled .536v before being replaced.
Fass lift pump steady at 14-15psi.
Restarts immediately after stall.
Alternator outputs 13.5-14v.
Potential issues:
Live throttle reading is between 10.2% and 73%
Truck will not reset APPS. Remains 10.2%-73% after multiple attempts.
While live throttle reading is stable with key on, engine off, with the truck on it oscillates ~9.8%-10.2%
Troubleshooting so far:
-I've tested the APPS sensor voltage while the truck is on and off with a multimeter and it remains stable, even during the hiccups/stalls. While all measures don't point to it being the cause again, a replacement is on the way just to rule it out completely.
-I've tested the idle at 6v and 5v. Symptoms change a little but remain.
-I've done the W-T mod. Nothing changed.
-I've re-cleaned each and every ground cable and terminal. Nothing changed.
-I've wiggled the cables while measuring, APPS voltage remained steady.
Does anything immediately ring a bell and sound like something you think you know what it is?
If not, where do I go from here?
Thanks for all the help.
