Bearing preload
2000 2500 Dana 80 rear axle. What should my pinion bearing preload measure with tires and brake drums removed. I forgot to measure it before taking it apart.
  • Replies 3
  • Views 239
  • Tractorman
    Tractorman
    From the FSM. The torque for the end yoke nut is 470 ft/lbs. John (10) Check bearing rotating torque with an inch pound torque wrench (Fig. 54). Pinion rotating torque should be: • Original Bearing
  • John
should be:
• Original Bearings: 1 to 3 N·m (10 to 20 in. lbs.).
• New Bearings: 2.8 to 5.1 N·m (25 to 45 in. lbs.).
(11) If rotating torque is less than the desired
rotating torque, remove the pinion yoke and decrease
the thickness of the solid shim pack if greater
increase shim pack. Changing the shim pack thick-
ness by 0.025 mm (0.001 in.) will change the rotating
torque approximately 0.9 N·m (8 in. lbs.).
Hopefully it works out right. I hammered a new nut on with my impact, then loosened it until the rotating torque was 17 ft lbs with no tires or drums. Old bearings.
There was an awesome write but all photos and the photobucket account was lost by that member so the page went blank.
@Tractorman is correct on the specs. Most impacts won't make the grade. The article is had talked about torque multipler gearbox for the torque wrench.
