Electrical gremlin or valve body?
I’ll start as simple as i can, we can expand as this thread goes on.
Basically, i am familiar with the AC interference issue and have “fixed” that by following the WT tutorial.
I rebuilt the transmission myself a few years ago and can’t completely rule out a valve body issue. I think a piece of debris could have made its way into the TCC plunger somehow and scored the bore it rides in, and when I rebuilt it i reused the same oil pump and valve body and torque converter. This problem didn’t show up right away and instead took a while to start happening.
Ive got a quadzilla installed in the truck currently.
Im experiencing a weird intermittent problem. It manifests through torque converter lock/unlock but does not follow the same rapid speed that AC interference does. Its much slower and completely unpredictable. Only happens in 3lock or 4lock but will happen at any speed (35-85mph) that those gears can be used.
Last week i hopped in to go to work and it was behaving as though the MAP sensor was unplugged, was not registering boost through the quadzilla, I hadn’t connected to the iquad in a while so I also noticed at that time that i had no fuel pressure reading. I unplugged and replugged those connectors and the truck ran perfectly for the next week, now its back to the same behavior. I thought, wow what a coincidence that both sensors use the same round 3 pin (deutsch?) connector, got some contact cleaner and dielectric grease and got no improvement. Still no fuel pressure reading so it may have been hammered to death and just needs to be replaced. Also using an aftermarket MAP sensor thats been installed for probably 7 years now.
A few weeks ago i got a multimeter out and confirmed that the TCC solenoid is giving the appropriate resistance and that I do have continuity through that whole circuit.
I have an autel ml629 scanner and am not seeing anything obvious in the live data nor do i get any relevant codes. I only have a code for grid heaters as i have them disconnected because the leads melted and i didn’t want a fire hazard.
Im hoping someone has insight before i order a valve body from randys transmission, its an expensive dart to throw at a problem that so far seems to be possibly related to the MAP sensor as well.
Maybe there’s a ground circuit I need to look at? Ive got really good battery terminals (napa military style) and oreilly brand marine deep cycle batteries.
Edited by 2000Ram2500
  • Replies 12
  • Views 1.1k
  • Tractorman
    Tractorman
    What about temporarily testing with a Voltmeter? Connect one lead to the OR/BK wire from terminal #11 at Connector #2 PCM connector and the other lead to ground and go for a test drive. When TCC is
What about temporarily testing with a Voltmeter? Connect one lead to the OR/BK wire from terminal #11 at Connector #2 PCM connector and the other lead to ground and go for a test drive. When TCC is unlocked - 12 volts should be present. With the TCC locked - 0 volts should be present. You might get some useful information with this test and it doesn't cost anything to perform.
  • John
I’ll find my alligator clips and give it a whirl. Might be a couple days I’ll check back in with what i find
Could you just check your AC voltage one more time? Take the truck out, warm it up, and leave it running. Now pull out your DVM and check the voltage at the BATT post on the alternator and the passenger side negative. Make sure no other loads are on. Then post your result voltage. You can still have a bad diode, possibly causing issues. Just double-checking values and make sure your power isn't polluted yet. Make sure to use a good quality DVM that has a 2V setting range and is capable of measuring more than just 60 Hz house power. (Like my old Fluke DVM does!)
Keep in mind 1st, 2nd, and 3rd gear are all hydraulic shifts. 4th Gear is electronic (PCM control) and the torque converter lock up is electronic (PCM control) hence the model / name 47RE - (4 gears, 7 score for 0 to 9 for torque, Rear wheel drive, Electronic shift)
  • 4 weeks later...
Im going to check for ac bleed through tomorrow. I lost my multimeter in my last move apparently. So im going to borrow my coworkers and hopefully his is capable of giving a good reading.
Im starting to think you’re right about it being a diode issue. Ever since you responded im paying more attention to it and I’ve noticed that it doesn’t act up for the first 5 minutes of driving but once it’s completed it’s first warm up for the day it will do it all day long. If it was a valve body issue i imagine it would do it 100% of the time not just after warming up. I was so sure it couldn’t be the alternator ive just written off that possibility for a couple years now.
That said, are you still selling the diode kits? I can’t remember if i bought one of the ones you used to sell years ago or not but that would have been around 2018 when I lived in Arizona.
I've got some of the older diodes with the post in the back of the alternator. Most alternator shops sell the diode packs for ND alternators. Bosch on the other hand, is soldered diodes so those are a bit different.
So i got lucky and found a fluke here at work. My coworkers was just a klein for household use but one of the work trucks had a good fluke onboard i didn’t know was there.
Anyhow. The results i got after a 20 minute commute followed by 30 minutes of idling. No extra loads the only thing running was the engine, radio was on but nothing playing.
The mVAC fluctuated as low as 24 and as high as 38.
As for which alternator i have, i cant see any markings but it’s got the two wire plug on the back and the alternator lug located on the back as well approx an inch and a half away from the two wire
Just a follow up edit:
After some searching I found that i have the Nippon Denso alternator not the bosch based on part images on oreilly website.
Secondly, i followed the suggestion to unplug the alternator plug and disconnect the charge wire. So I did that as soon as i got home. The lock/unlock issue persisted while i was on my way home and after unplugging it the truck ran perfectly as it should.
So at this point i can only reason that the alternator and/or diodes are the culprit.
What I do want to reiterate is that ive had this problem before but it manifested in a completely different way. Previously it was almost non stop rapid succession of lock/unlock. This time was very sporadic and unpredictable and nothing like the first time.
Now i must decide on a whole alternator, a diode pack, or is it a reasonable idea to install a second diode between the alternator and the battery. The alternator is the original alternator from 2000 and it now has 221k miles on it, i did replace the diode pack around 2018 which was about 60k or 70k miles ago.
Just following up-
Im gonna order a new rectifier. Looks like INR734P. Seems like the most logical route and what i can reasonably afford right now. I have to tow a large 5th wheel Saturday so heres to hoping this rectifier gets it fixed and i get the part in by friday so i can get the repair done
I have. Done it several years ago actually. Grounds are all attached to the timing case and alternator connected to the passenger battery
Battery cables have also been replaced and i have the heavy duty copper lugs bolted in to the napa “military style” terminals (napa part# 728222 for one of them, positive and negative are different numbers) They are really awesome and give a good solid connection since they have thru bolts.
  • 2 months later...
just following up on this-
i got the correct diode pack (first shipment was incorrect part pulled by warehouse staff). I was really planning on working on the truck when the wrong part came in so i went ahead and pulled the 2 wire alternator plug out, sprayed it with electrical contact cleaner and put some dieelectric grease in there, did the same with the charge wire where it connects to the battery terminal minus the grease, and the truck has improved significantly since. i can actually count on one hand how many times the torque converter has unlock/locked since that weekend. i never ended up pulling the alternator and still have the new diode pack in the box in my glove box for now, i'll get around to changing it eventually because when i was towing this 5th wheel it still did the unlock/lock under load.
now i have new issues
last week just one time i was in a drive thru and i normally turn the truck off to be kind the the people wearing the headsets and so i can hear them, when i went to restart it, it didnt start up right away. you get so used to holding the key down for a short time i thought maybe i didnt hold it down long enough but when i held it in the start position it took like 4 seconds to start (normally this thing barely finishes the first engine rotation and its running)
now jump forward a couple days to earlier this week, i hop in to go to work and it does it again only this time it took closer to like 8 seconds to start. next day, little bit longer. now today when leaving work it took like 15 seconds or more to start, long enough that the dinger actually dinged at me a few seconds before it finally started. with all this, for the first few moments after it starts it has a rough idle but smooths out. i noticed yesterday leaving work that my quadzilla isnt being utilized, i connected to it today on my way back into work and noticed im not getting a fuel psi reading, map psi is frozen at 2psi, apps position is frozen at 8%, but other things like egt, iac, ect, timing, all seemed to be reading properly or at least gave that appearance of believable live numbers. so, leaving work i connected my actual scan tool to the obd port (its an autel ml629), and through the scanner i am getting an apps reading, i can see the map changing (31 inhg to 60+ inhg depending on throttle/load), and i have a new code, a p1689
its raining and i lack a covered location to work on it so hopefully tomorrow before it gets hot i'll get under the hood and see what i can see. after some searching it looks like a p1689 can be a few things so i'll try to check out anything i can
Upon a quick inspection it appears i have some wiring damage at my vp connection. Seems like a good place to start to me
  • 5 weeks later...
just following up finally to close this thread
so these pumps dont have a yellow wire, even though it really looks like i have a chewed up yellow wire, that was actually an old paper tag of some sort. i found a replacement connector and this weekend i dug into it. i took the wire loom off and found absolutely no wire damage. however, the outside edges of the connector were bowed out convex like and the rubber seal was smashed up inside the connector. i remembered reading on here about how these pins can lose their ability to make good connection so i proceeded with the repair. and it seems to have fixed the problem. i cleared the codes and after 4 or 5 trips i have not seen any codes come back. whats interesting is i had a p0220 and a p1689, neither of which have come back after replacing this connector.
truck is now running great, sort of...
in the process of this repair my lift pump stopped running but thats a different issue than this topic is really intended for
