- Replies 7
- Views 4.1k
Mopar1973Man 3 posts
Wild and Free 2 posts
ROAD RAGE 2 posts
Been trying to get this thing fixed, Went through the grounds and the 1488 and 522 codes keep coming back. Trying to trouble shoot from the book but seems it's just getting more confusing:mad: The book:1488= Auxiliary 5 volt sensor feed is sensed to be below an Acceptable limit. 5-volt Supply Voltage low. Sensor Supply voltage for E C M sensor is too low. book: 522= Oil pressure sending unit voltage input below the min acceptable voltage. Question? is there a sensor that supplies 5 volt's to the E C M?I thought the E C M did the 5 volt thing.:rolleyes:Thanks Ed.
