Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I bought a used 1998 24V QCSB (185k) about 6 months ago. Occasionally, it will fail to start for exactly one hour. Then it will start right up. I suspect an aftermarket alarm. I have no fob that might have come with the alarm, but there is a switch hidden under the dash which enables/disables it. Same problem not matter which position the switch is in. Most of the time it starts just fine. But has failed to start twice in the last week. So, the frequency may be increasing. Any ideas at all? I know the alarm has lots of wires but haven't any idea where to start to troubleshoot. And it may not be the alarm at all. If it is the alarm shutting down the ignition and it has a timer, can I set the time to a shorter duration?Lastly, I really don't need the alarm at all and am willing to uninstall it. Anybody know where the tentacles of the alarm wires reach? ECU? Fuel pump? If I take it out, I want it all gone.Any help is appreciated.Thx,bb
