- Replies 8
- Views 3.9k
hawkeye213 3 posts
JOHNFAK 2 posts
stodg73 2 posts
Mopar1973Man 1 post
Ok last July my if you remember my tranny went out on my trip to Montana. I remember posting that about an hour before my tranny blew up we were climbing up a pretty steep hill at about 65 mph and I got like a 2 sec squeal and it sounded like it came from the turbo I pulled over and popped the hood and took a look and didn't see anything out of the ordinary and I could not make it do it again. So we just went on. An hour later the tranny blows. I just figured the noise had something to do with the tranny. OK here we are 5 months later. The other day I am driving down the road upshifting to 6th and when I hit 65 mph I get this same squeal again. Its just a short little squeal I look at my gauges everything is normal. The truck doesn't miss a beat. It doesn't sputter or cough or nothing. Last night on my way home it does it again but this time my check engine light comes on. Same thing upshifting and at 65 MPH I get the squeal. I look at my gauges and everything is fine. So I start watching my boost and try and make it happen again when I get to 65mph I get the squeal again and I am watching my boost gauge when the squeal happens my boost gauge is at 10 and then drops very quickly to like 8 and then immediately goes back to 10 after the squeal stops. It happens so fast that if your not watching the gauge when it happens you will not see it. The truck runs fine it doesn't miss a beat. I pulled the code an I got pcu 0500 and ecu 1693. So my friends what now. Your thoughts and help would be greatly appreciated.Thanks Rob PS I just went out and started my truck and the engine light is off now. Have the same codes P PCU 0500 P done P ECU 1693 P done
