Clutch Reco
Looks like I will be needing a clutch, getting some chatter in 1st. What do you guys recommend?
  • Replies 2
  • Views 1.7k
Stock... You not really putting out much for HP to require a larger clutch. The stock clutch is good to ~350 HP at the flywheel. But a Southbend Con OFE is a nice small upgrade to ~450 HP at the flywheel hold.
that is what im running and i like it so far. i would recommend using the updated heavy duty slave clyinder and master i think it would be a little nicer to mash on than the stocker that im using!!!
