Never seen this before. Sun set and then it made this line. Camera reduces it a little, it is a very bright line. I've never seen the sun do that before through the dark clouds like that. Thinking it was just the sun shining on the bottom of the clouds or something.
Here is the bigger version http://www.mopar1973man.com//isx97/Other/IMG_3042.JPG
Posted Image
Here is if I adjust brightness and contrast to make it a little more obvious.
Posted Image
  • Replies 10
  • Views 1.9k
its project HAARP they can heat the atmosphere into a plasma and communicate with submarines anywhere in the world. russian nukes could be melted if in the flight path. they can put enough energy into the atmosphere to create its own aurora. :stuned: where is my foil hat again?
Funny to see other people know about HAARP. I'm not very fond of the story and things I've heard about HAARP... Hey would you mind sharing a chunk of tin foil with you fellow members... :lmao::lmao2:
That is interesting though. I'll have to read up more on it when I'm more awake.
