2001 cummins transfer pump voltage
Does anybody know the voltage when starting .When I turn the switch to on I m picking up 12 volts for 2 seconds & then it drops to 8 volts? Then when I turn the switch to start & let go I get 12 volts for 25 seconds then voltage drops to 8 volts? Why does it drop to 8 you would think it should drop to 0 volts.These test are done at the transfer pump connector.
  • Replies 7
  • Views 5.1k
does anybody know where to go to check voltage specs when turning ignition on & then start position,my voltage never drops to 0 it goes down to 8 volts only?:cookoo:
Not sure of your question.:shrug:
what happen is I wanted to check the pressure between transfer pump & vp44 ,my gauge was reading 0 psi so I unplug connecter on transfer pump & check voltage with my meter and the results were with key on 12 volts for 2 seconds then voltage went down to 8 volts ?then I turned the switch to start & let go I was getting 12 volts for 25 seconds & then the voltage dropped to 8 volts until I turn switch to off ,voltage dropped to 0 ,why is it staying at 8 volts you would think it should drop to 0 volts.Afterwards I pull the pump out and it s seized so ordered a FASS pump as replacement,Ijust want to make sure of the good voltage before I do the switcharoo.:(
Sorry I can't help with your problem but welcome to the forum and what part of Canada are you from?
Up in the" BOONIES" northern Ontario,just bought the cummins with a defective transfer case,I did those repairs & now I want to make sure I have enough fuel press. before I start on the modifications.0 psi is not enough ,I ll replace the transfer pump,I m worried about the 8 volts I have when I flick the switch,this can be hard on a 12 volt pump
Either its 0 Volts turned off or 12 Volts turned on... Full controlled by the ECM...
Posted Image
OFF should 0 Volts
Cranking should be modulated 12 Volts (Square wave)
Running should 12 Volts solid.
No there is no relay or other controllers. Either the ECM has a bad ground, poor power supply, or ECM is starting to fail.
Great ,thanks for the info I ll check the ground to start:)
