Engine Rewiring
I decided to rewire the engine compartment a few weeks ago. I cut every wire in there and took every piece of black tape and ribbed sheathing off and have been left with nothing but wires. My plan is to put the PCM/Fuse Box/Grid Heater Relay on the hood, right on the back drivers side corner. I don't think there will be any issue with slamming the hood and everything getting shock absorption. I have some plans to absorb it a little anyways, though I don't think anything will happen. The initial plan was just to take the ribbed sheathing crap off in lieu of braided nylon sheathing, like what the cruise control has on it going to the throttle. I was going to put it on every single wire. After looking at it some more, I decided to redo everything, every part of routing it. By putting the pcm on the hood, I can get rid of the entire loom that runs along the top of the firewall. I starred at it some more and realized I can get rid of the entire loom that runs along the top of the engine next to the valve covers. There will be hardly any wires on it now and they will be hidden. I am going to use the fuse box for now, but I have plans on getting rid of that big piece of crap as well. This thing has taken me a long time because of how many wires there are and how to run them and where to run them and.... but I finally got one ran to the passenger side headlight lol. I have been working a lot so I don't have much time to work on this thing but I am going to aim for one connection a night now, be done by 2012 :lol:
  • Replies 28
  • Views 6.9k
I've had to track them all down so many times that I pretty well know how every single thing on that truck is wired. How big the wire size on everything is, all of it. So now I can add wiring to my list of things I'm not afraid to do anymore on my truck. I keep doing things like this because I want to know what to do when I end up on the side of the road. I haven't had a single problem with the truck but I am hoping my effort pays off and the whole thing leaves me stranded so I can have a chance to fix it. I don't see why I have to always fix everyone else's stuff, why won't mine break for once :lmao: It's depressing really :lmao2: Bad part is, all I really have left to take apart is basically the p7100. I am a little sketchy on taking all the bolts out of it. I think it is simpler than I am thinking but I don't want it to end up costing me $1000 if I screw something up.
Just remember, the position of the barrels is critical for proper fuel volume and balance.
I got it done today. Well not really. I got it to the point that all I got left is the battery cable connections and alternator connection so I just jumpered it all up with jumper cables to see if anything actually worked.Everything somehow worked, EXCEPT, the WTS/WIF/Check Engine/GEN lights were all on, the RPM doesn't work, not sure what else, everything else seemed to work fine. According to the schematics, there is this "sensor ground" that shoots off the PCM to all those things I listed that don't work, well I said hell with that and just ran all of those to a normal ground. I am thinking it needs to go through the PCM for some reason. I didn't think it would matter but I guess it does. Will just have to use dads truck to pull the trailer tomorrow, at least its only 40 miles away. I will fiddle with it through the week and hopefully get it perfected.As for pics, ehhhh, it looks like crap. The wires are all too long, there are a million wires more than I expected.... I might take one later on in the week but I am to the point to where I just threw it together and am awaiting plan B. Now that I know what not to do I can do it right, but I think it will be a long time before I take it back apart, unless I buy another cummins.
:doh: D'Oh! I could of told you that one about the grounds... :rolleyes: Dang... So close but so far away... The sensor base there grounds on PCM grounds not body gorund. Same with ECM on the 24V truck they base off the ECM ground not body ground. This is why its so critical for grounds to the PCM/ECM be in good condition because the internal ground that the ECM/PCM create are based off them.
Well that sucks. I used a ground bus bar and it is about the only thing that turned out good. Now I gotta undo half of them.I can't believe everything worked though. I cut a LOT of connections out, a lot of connectors, a lot of wires I didn't even put back. Still, what a PITA lol. I am planning on drawing out a layout of every wire and getting it all on paper next time so I know how everything will work. It actually looks perfect from about the brake reservoir and over to the passenger side. I won't get into how the other foot looks :mad:
