- Replies 10
- Views 3.9k
Mopar1973Man 3 posts
jlwelding 1 post
Dave3500 1 post
[list=]
Hello, just got done sealing up the side tapet cover and put in a new cam sensor on my 2001 dodge ram 5.9 had a hell of a time getting it running after installing the vp.but i got it running and ran great until i put my last tool back in the box..it spit spudded and was like it was lacking fuel with engine running i pushed on the sharder valve just driped a little fuel, pulled water drain same thing...replaced lift pump with new one started right up missing for a bit then it was fine...now the old pump was running with the key out of the ign...???also heater grid sol. were clicking on there own..truck runs great has more power then it ever did...well now i have the p1689 code and it will not go away..cleared codes and when i was checking all my wireing with key on out side temp in the 70s the heater grids were on full blast and smoking..pulled main sol. wire off battery to get them to go off..anyone have any idea what is going on with this thing only had it a few months and love it..and even with the engine lite on it has way more power then it ever had.Sorry for this novel but iam at witts end...Thanks to all..
