- Replies 13
- Views 3.3k
flagmanruss 5 posts
ramman 01 4 posts
JOHNFAK 2 posts
MnTom 1 post
Wasn't RUNNING that is. We were on our way to drop the truck off to get the heat/AC fixed. I'd already driven 25 miles... I was going 35-40 when suddenly I lost the power steering... cause the engine had shut off. I pulled off the road into the only space available.
I still had 1/4 tank of fuel... old fuel been in since Sept/Oct. I've only been driving enough to keep the brakes from freezing.
The engine turns over nicely. No run. I did the key thing. PCU -------- ECM --------
The mice had built a nest in the air cleaner (which I'd recently cleaned out)... mostly insulation material from the firewall. (Hood insulation removed long ago.)
My buddy came by, put another 4 gallons of fuel in it (to be sure). He checked the schrader valve & got a spray of warm fuel. Truck still has OEM lift pump. I hope that's not it. (No Codes)
I had to get the truck moved... AAA flatbedded it to the nearest dealer. They promised to look at it this afternoon, $80 to run the diognostics. I have no clue at this point. 56,000 miles
edit Dealer called back. (Good service... 4 hours to check it out) Lift pump. Dealer wants $1200 to install the intank pump that I don't want.
