Injector Virgin
2005 Ram 2500
Begining to hard start. Overnight seems to be the worst. Died once. No codes. Fuel filter recently changed.
Boss thinks its the injectors because the same thing happened to a friend of his. Wants me to change them.
Never done it before. [He thinks it should be like changing sparkplugs]
How big a job is it? Do you need special tools?
Looking for a manual. Is the "2005-DodgeFSM.Zip " a service manual? Not sure if I can open the file, haven't tried yet.
Any advice would be appreciated.
Thanks,
Rob
  • Replies 24
  • Views 6.3k
I don't beleive it to be difficult, but some mechanical knowledge will be needed. If its your injectors I would pull them, ship them to DDP and have them tested.
I don't think that is a very hard job, from what I've gathered. I'll let you know more after I change mine on saturday. If you do find that it is your injectors I would get on the horn and find some fast, it seems like they are very hard to come by, I could not find any stock Bosch 505's. The quickest any parts supplier could get them was 2 months from now. I would also leave the truck parked in the driveway until you figure out the problem, if you drive you risk distroying the motor.:2cents: Hope this helps
Hi Windy, Looking forward to a report. Good luck Saturday.AH64ID- I think theres a shop here that can do it.Thanks for the site Michael- it's awsome
Make sure its the fancy (i.e. $$$$$$$$) Bosch machine, I don't believe anything else can fully test them. I understand there are only a handful of them in the country.
Is there nothing else that would make the truck start harder? I wouldn't replace injectors unless I knew for sure they were bad. That's way too much $$$$ for Easter Egg troubleshooting.
Being that all diesel engine rely on having pressurized fuel to fire the injectors to make them start.
No codes.
So typically I ask for fuel pressure and error codes to see if there is something else wrong. If there is no error codes then all the electrical and electronics are considered good and operational. So that means its all fuel pressure from there on out...
Any other symptoms? Smoke? Fuel in oil? Are your heaters working? Have you changed your filter since it became hard to start?
I downloaded WinZip and Part 1 and 2 of the FSM. Clicked on file to open, entered password "pdftown.com"The progress bar went all the way to right and then I got message that said there was a problem. Looked at the error and the last part said there could be a problem with the password ??? -Fuel filter will be changed first.-No fuel in oil. No smoke.-Will look at heaters when I get the FSM As far as fuel pressure goes, I'll have to get that tested- don't have a gauge. Imagine they're expensive?
AH64, I tried the version you linked to but still couldn't open it.I did open the 2006 FSM with no problems. Are the '06 and '05 close enough to see how to replace the injectors and do things like test the heaters and fuel pressure?
Very interesting. For those things they should be. There is a slight difference in how the valve cover/rocker cover mounts. But if you have any questions let me know and I'll reference my 05 manual.
That's the one I tried the first time and it still won't open for me. I get this message:Extracting 2005-DR-SM.pdf Error: CRC mismatch in file "2005-DR-SM.pdf" in the archive "C:\Documents and Settings\Rob\My Documents\Downloads\PDFTown.com-2005-DR.part1.rar" - possible wrong passwordI'm using WinZipUsed "pdftown.com" password
In the manual they show two "special tools", one for pulling the tube that feeds the injector and one for pulling the injector. Is there a way to pull them without the tools?
UPDATE/EDIT:
I was able to open the file that AH64 uploaded. I'm on a different computer and using Interenet Explorer. Maybe it was a problem with Google Chrome which I was using last night. I'll try IE on your file when I get home.
On the intake heaters, do you check resitance or will they be warm to the touch- key on
Batteries were low from trying to start it. I had a hunch they were bad before that. I put in a new set and the truck starts fine now even after sitting for a few days. I guess there could still be a problem but won't find out until he starts driving it again tomorrow.Just to be clear, in the beginning the truck cranked ok but wouldn't start.
Well problem wasn't solved.
I've been posting on other forum because I need some guidance soon.
2005 125,000mi
P0148- Fuel pressure
It cranked but wouldn’t start. Changed the fuel filter but still wouldn’t start. Put in a new set of batteries and it started for 2 days but the driver thought there might be a miss. Ran like crap a couple of times and he noticed black smoke when it did.
Oil level about 3/8” above full. Would this point to a bad fuel injector? I read you can use an infrared checker on the exhaust ports to look for a cold cylinder- is that correct?
Also I cleared the code and heard a rapid clicking noise when I turned the key on- towards the back of the engine around head level. It lasts for about a minute. I heard this before when we first had this problem but don’t ever remember it hearing it previously.
Don’t want to do the injectors if this sounds like it might be something else.
Any help would be greatly appreciated."
