Carter HD Elc lift pumps.
- Replies 12
- Views 6.5k
Mopar1973Man 3 posts
dorkweed 2 posts
Perrysburg Dodgeboy 2 posts
DennisNYS 2 posts
I had an interesting conversation with a Carter fuel pump engineer this morning. I have been researching just what way I want to go for a new lift pump and filter system. I just can't pay $400+ for something that costs the dealer $100 at the most
. So anyway carter sells a pump (P4601HP) with 18 max PSI, 3/8" lines and a 100 GPH flow rate. More then enough for a stock to lightly modded truck. However I was told that the pump MUST be mounted with in two feet of the tank AND the inlet MUST be below the tank. If the height is not fallowed the fuel will siphon back into the tank and shorten the life of the pump. The fix would be a simple check valve mounted between the tank and the pump. This got me thinking, I wonder if the pump kits they sell have an internal check valve or not. BTW the P4601HP kit lists for $99.95/129.95 and comes with 3/8 hose fittings, clamps, mounting bracket, wire stubs, bolts and nuts. Then I'll add a single Cat filter kit after the stock filter for $99 and a bigline kit for $39 and I'm good to go. The only thing I need to come up with is a block to replace the stock carter pump on the OEM filter housing, any ideas for that. I could make one when I get back to work but, if it can be bought I'm open for that.Don
