VP44 OR WHAT
Been haveing problems for a long time. The eng. surges eradict but only slightly. When at hwy speed say 65 you let off and rmp get to about 1500 then put it in nuteral rpm drop quick to about 700 then pick back up,if A/C is on it almost dies. No white smoke no black smoke fuel mileage is normal. And when you rev up the eng. then it starts droping it has a little rev up right before idle. I here common rail motors do this, why would a vp motor do this. I changed the inj. to 75 hp and it started this so I had rv 275's rebuilt and put them back in and still the same no change.I dont no if this means anything but rpm gauge bounces a little at idle. Also I loosen inj. lines so there would not be any problem with cross over tubes lineing up with inj. and retighten. I always wash eng. where inj. lines go into head so there is no dirt getting in there. I dont know how much more I can do.Thanks for your help.Joe
  • Replies 7
  • Views 3.5k
Installed new crossover tubes and still the same. No change :confused:
Hmmm... JL... Do you have any new error codes at all?You might try a cam sensor for the tach jump but I don';t think that going to cure the strange idle jump issue... Is there someone you could swap VP44 with? :confused:
Had the same issue on mine for about 1500 miles, just gave up. About the time I did VP died, and that was the VP I put in when I put my fass on it. sorry
The only person I can swap with is my son and his is a HO motor.Wont work, will it? I hate to ask someone to swap. My luck I will drop key in oil pan LOL `:(
Hmmm... If you a SO Engine... Nope... Dumb idea though... :confused: As for the key I've got a solution for that... Another member told me... "Super Glue!" LOL
  • 11 months later...
Super Glue how cool!
yes...tap the key in...make sure that it is in the right positon ...tap it in good and make sure that the top of the key is paralell to the shaft of the pump.then put of few drops of super glue where the keyway meets the shaft.if it is in the winter time..keep the pump and the parts in the house so it will be at room temperature so that the glue will dry for sure.thats what i did and it turned out fine.:thumbup2:
