- Replies 6
- Views 3.9k
Mopar1973Man 3 posts
jlwelding 3 posts
Ok gang I need you guys to double check me on this here...Truck Specs: 2002 Dodge Cummins - 128K miles - 2500 - Stock(No its not my truck!)Error Code list:P0113 - Intake Air Temp Sensor Voltage High Intake air (charge) temperature sensor input above the maximum acceptable voltage.P0118 - ECT Sensor Voltage Too High Engine coolant temperature sensor input above the maximum acceptable voltageP0238 - Map Sensor Voltage Too High MAP sensor voltage input above the maximum acceptable voltage.P0343 - Camshaft Position Sensor Circuit High InputP0563 - Charging System Voltage Too High Supply voltage sensed at ECM too high.P0577 - Cruise Control Related MalfunctionP1286 - Accelerator Position Sensor (APPS) Supply Voltage Too High High voltage detected at APPSP1475 - Aux 5 Volt Supply Voltage High Sensor supply voltage for ECM sensors is too high.I've not had a chance to verify the battery volts while running. But at idle the engine is randomly reving up to nearing 2K on the tach. Gauges are going wild all rising up randomly. Durin the short time I was there the coolant temp gauge pegged out (cold engine).My thought on it is the PCM voltage regulator is fried out... But I want to make sure and double check myself against the group here...
